micropython-reticulum on ESP32-S3 feasible performance?
Question Discussion
I just want to quickly jump in here. I'm the developer of micropython reticulum. Since the above was posted, I've ported the problematic modules in C with micropython bindings - the critical parts were crypto modules and bz2 module. I've kept a native micropython fallback versions just in case. This dramatically increased the performance of the port. I've been testing it now with sending images, voice etc in small networks and it behaves good both on LoRa and TCP interfaces.
Hi!
This is your repository, right? https://github.com/varna9000/microReticulum_Firmware
I'm following the steps for building firmware for the Seeed XIAO nRF52840 + Wio-SX1262.
During the process, I discovered that the files "xiao_rnode_setup.py" and "provision_xiao.py" are missing in your repository.
I'm afraid that without provisioning EEPROM, nothing will work.
Pity, that both projects are slopped
Otto wrote:
Hi!
To be fair, I didn't put much effort in tidying up this particular repo. I kind of used Claude to blindly sort out the pinout and cut off some bits so that microReticulum doesn't die on the xiao nrf52840.
I give more attention to the Micropython port. I understand that some might not be keen on the AI tooling, but this allows more people to get engaged in projects like Reticulum and speed up the adoption. I've been coding with Micropython on microcontrollers before AI was a thing, so wouldn't call the port a "slop" as Anonymous does above. In any case, it allows flexibility on adding features (like standalone camera reticulum node), works for me and hopefully for others too.
