An Introduction to Network Stamps
The text below is taken more or less verbatim from the new "Protecting Open Networks" chapter of the Reticulum Manual. I wanted to post it here as well, to give an early head-up on how everything works. Release is getting very close now.
Reticulum is currently transitioning towards full, on-network stamp verification and enforcement via a phased transition:
- The
1.6.0release completely implements the required mechanisms, and will start excercising the verification system in the transport backend. By default,1.6.0does not enable full stamp generation, emission and enforcement, but all of these options can be early-enabled in the configuration. - The
1.6.1release will enable full stamp generation and emission of all types by default, but will leave the enforcement a configurable option. - The
1.6.2release will complete the transition, activating full stamp enforcement across all the systems.
The stated version numbers are the intended release sequence. If any issues or implementation problems are found during the initial network deployments, the transition points may be pushed later than this plan by interim releases.
While you can create entirely closed-off and private networks with Reticulum, the protocol itself is open and permissionless. On widely interconnected networks, anyone can create identities and globally reachable destinations without external permission or approval, and establish links anonymously over the network.
Such capabilities are powerful, and a required characteristic of a truly functional communications fabric, but also raise very large challenges, that have been almost impossible to solve in legacy networking technologies.
Reticulum approaches this particular problem, like most others, by employing cryptographic principles. This provides a comprehensive, multi-layered repertoire of defense mechanisms, which can be composed and employed in very effective ways.
In contrast to other networking paradigms, these mechanisms do not have to be bolted on to the application layer in hindsight, but are a core part of the protocol itself, which means that they can be applied universally and effectively:
All nodes help combat spam and network abuse, according to the rules set by the actual owners of supplied resources - not by any bureaucracy or external authority.
Rules and requirements can be adjusted live, dynamically and directly, and by those that actually operate and run the infrastructure and services.
The system has been designed so that it becomes very cheap computationally for resource-providing nodes to verify or reject traffic, and very expensive for malicious nodes to abuse the shared resources provided by the network’s operators.
Cryptographic Stamps
All networking primitives that consume shared network resources are gated by stamps. A stamp is compact, cryptographic token that proves that a certain amount of computation and energy has been expended in its creation.
The amount of such computation required for a stamp to be considered valid can be configured individually by the operator of the resource being made available, whether that is network transport, a node providing information for retrieval, a shared voice room, or something else entirely.
While the core functionality is completely automatic, and handled by Reticulum itself, the primitives are made available at the application layer API as well, so that developers can use them to implement further protections, if required by their usage scenarios. In most cases, however, simply setting the target values and required costs for the built-in mechanisms will be sufficient.
The value of a stamp is a decimal representation of how difficult a stamp was to create, on a scale from 0.0 to 100.0. The scale is exponential. An increase of one point is equal to doubling the average compute time required. Fractional values are supported, such as 14.125.
Internally, the fractional part is quantized to 256 different values, giving an approximately 0.4% difficulty increase per step. You can use any decimal number when configuring stamps, such as 9.3691 and you do not have to worry about “landing on” the correct step values. Reticulum will automatically handle the quantization, wire-transport representation and value comparisons.
The term cost is used everywhere a stamp value requirement is configured or specified. In general, value refers to the actual, determined value of a given stamp, cost refers to a value requirement.
Base Primitives
Reticulum provides two types of base stamp primitives:
- Detached stamps can be tied to any external information, and are useful for stamping both static information and for one-time verification purposes. The stamp itself is a detached, short binary sequence, typically 14 to 32 bytes, that can be verified directly against the stamped material.
- They can be configured from relatively easy to compute, even for embbedded systems and microcontrollers, all the way to something that is practically impossible, even with all the compute and memory on the planet.
- Embedded stamps are tied directly to a Reticulum Identity keyset, and embedded within it. The keyset itself contains the stamp, and there is no external, detached byte sequence for them.
- Anyone can verify the value of an identity-embedded stamp simply from the public key material of the identity.
On-Network Types
The base primitives are used to implement scenario-specific network-level primitives that, if configured correctly, make spam and network abuse expensive, but validation and enforcement cheap and efficient.
- Destination Stamps are detached stamps associated with reticulum destinations. They are included in all announces sent by a destination, and by verifying that their value matches a transport node’s cost requirement, they can be either accepted for rebroadcast onto the network, or rejected and dropped.
- Destination stamps are one-time generations, and are reusable across announces. They limit the number of new destinations that can be created, and makes it expensive to spam a network with destinations that do not provide anything meaningful. As such, these stamps will typically target relatively high values, and their cost requirements should be set accordingly.
- A generation time for such stamps in minutes rather than seconds can very well be reasonable on large, open-access networks. Due to their detached nature, they can also be pre-generated off-device (and do not require the private key material for generation), so that even low-powered nodes, such as microcontrollers, can use high-value destination stamps, by having them generated and loaded externally as a one-time procedure.
- Path Request Stamps are also detached stamps, but generated individually for every path request emitted on the network. These will typically have a much lower cost requirement than destination stamps, but if a node is overwhelmed by path requests, it can be tuned higher.
- The stamp is generated against the individually unique emission, so that unstamped or low-value path requests for a destination cannot disrupt the resolution of legitimate ones toward that same destination.
- Link Request Stamps embedded stamps, carried in the ephemeral link request keyset. They are therefore completely transparent to the network, but can still be verified extremely quickly by any node along the link request path, who can then make a decision on whether or not to transport it.
- Link request cost targets are set by the endpoint destinations individually. Every destination that includes a stamp in its announces will also include link request cost signalling. This means that any node that hears an announce from the destination will also know what link request stamp value to target, when establishing links to that destination.
- Furthermore, spam and link request abuse can be filtered before even reaching the destination, if at least one node along the path validates the link request stamp value and cost requirement.
All of the stamp primitives, functionality and on-wire signalling is transparent and backwards-compatible with older versions of Reticulum transport nodes. This means, that even if a node doesn’t itself understand stamp functionality, it will still transport all the required information. Stamped announces, path and link requests can cross older, non stamp-aware network segments transparently and unaffected.
