Doc bug in manual: wrong place of default identity for rncp
Started by Rudi Mentaire 756c9adefd2ed337... ·
Hi,
I'm currently reading the manual (which is a pleasure!), but found a small annyoing documentation bug: in "using" where the small tools are described, it is told that "The default identity file is stored in ~/.reticulum/identities/rncp". This is wrong I think - the correct path is
/RNS/Reticulum.py:
  L:250  Reticulum.identitypath  = Reticulum.configdir+"/storage/identities"
with one additional directory component named "storage".
Thanks Rudi, forgot to change those a while back when the directories where restructured! Fixed now, will be out soon :)
Thank you 😊
