In micron image tags, I know w=n means width=native.
But what is w=50?
is that 50px, or 50%?
And 50% of what? Of the available page width, or 50% of the image width?
And is this documented somewhere, or considered to be 'experimental' from source?
I searched for the FM so I could RTFM but failed. And i searched a lot.
The reason I ask is two fold. First, because I'm hosting a small gallery at a3ab2d22647bf8a67937d229d3cbc506:/page/gallery.mu which I wanted to share, but now I don't know if my images will render correctly depending on the client used. This is annoying, because I don't want nomadnet to become the kind of place where we test for user agents. That's the legacy web type problem.
Second, because I just raised a bug with MeshchatX rendering 50 as '50 pixel wide' instead of 50%. And then, when I used 50%, it would render at 50% of the image width, but nomadnet over kitty seems to render at 50% of the available page with, and setting it to 100 fills my screen. This make no sense.
You can see where this is going: given there is no manual to refer to, I genuinely cannot decide which client is rendering 'correctly'. Part of me thinks it must be nomadnet , because nomadnet is canon.
But then, if nomadnet is correct, why is it rendering 50 as '50% of page width', which on my mac just happens to the be same size as opening the files in preview (sounds incorrect to me) . When i set w to n, expecting 480 pixel to look like 480 pixels, yet the image appears exactly twice as big as the files as seen in preview.
In other words, it's genuinely impossible, unless i was to go into the nomadnet codebase and look at the renderer, to know who is right.
Sorry for the wall of text but I have ADHD-H and I won't sleep until I figure this out lol
