My thoughts on design practices for adaptive path request and link establishment windows
Started by Zenith ·
This is just a quick post of my thoughts going over some findings from applications with regards to cold path request and link establishment timeouts for slow interfaces
One issue is that many applications (MeshChat, NomadNet, and MeshChatX, inherited from MeshChat) set their own timers when it comes to waiting for a path response and link to establish for the first hop.
The first thing here is: Don't use timers unless they are absolutely necessary. The Reticulum API is built to handle all of this happening asynchronously. But when you have to use timers, like say for Nomad page downloading, this is my recommendation:
In MeshChat, the link and path establishment timeout are both pinned to 15 seconds for accessing Nomad pages for example
https://github.com/liamcottle/reticulum-meshchat/blob/45f89a8fca79f63501659d192577e880380e6cc0/meshchat.py#L3436
https://github.com/liamcottle/reticulum-meshchat/blob/45f89a8fca79f63501659d192577e880380e6cc0/meshchat.py#L3479
Fixed timers like these will always fail over slow interfaces. Consider a packet radio link where the net throughput is 125 bits per second or super low LoRa CF/SF settings. These are all valid Reticulum interfaces.
At a 15 second path request timeout, a full round-trip for one path request will take 234 bytes and a little more with an IFAC.
At 125 bits per second, this is not possible to achieve in a 15 second window. At 250 bps, it just barely fits in the fixed timer with no margin at all.
So what is a better way of doing things?
Get the lowest advertised bitrate of an online interface, clamped to 50 bps, and compute how long it would take using an MTU to get the first cold path request timeout.
The drawback is that a instance with mixed interfaces (Some slow, some fast) will always wait that ceiling for a first cold path request. This is unavoidable because we don't know what itnerface it's sitting behind. But the alternative is that path requests fail always every time.
I put an example of this as a PR into MeshChatX which you can find the code for here, in path_utils
https://github.com/RFnexus/MeshChatX/commit/f785e6a896205c85ecbfa0d054a04c9fc2b81d10
https://github.com/RFnexus/MeshChatX/blob/f785e6a896205c85ecbfa0d054a04c9fc2b81d10/meshchatx/src/backend/path_utils.py
The simplest form of this looks like:
def path_response_window(destination_hash, reticulum=None):
    if reticulum is None:
        reticulum = RNS.Reticulum.get_instance()
    window = reticulum.get_first_hop_timeout(destination_hash)
    bitrate = slowest_online_bitrate(reticulum)
    if bitrate:
        window = max(
            window,
            2 * (PATH_EXCHANGE_BYTES * 8 / max(bitrate, MIN_WINDOW_BITRATE)) + 10,
    return max(window, RNS.Transport.PATH_REQUEST_TIMEOUT)
We compute the path request timeout based on the actual MTU it takes over the air.
The next is link establishment timeouts. Every application should use the timeout reported by Reticulum versus it's own timer. Reticulum already computes a timeout for every link it creates with link.establishment_timeout but I don't think the API has this in the documentation anywhere
No application should use a flat timer for this. It should always use what is reported by RNS, and my suggestion is to add a little bit of margin to it, maybe +3 or +6 seconds.
timeout = getattr(link, "establishment_timeout", None)
You should also always use RNS.Reticulum.get_instance().get_first_hop_timeout() instead of RNS.Transport.first_hop_timeout() because if your app is a client of a shared RNSD instance it will just use its local socket timeout and not the interfaces.
Those are all my thoughts for now, there may even be a better way of doing this and I would like to hear some feedback or suggestions on what the best patterns are when considering very slow interfaces which a lot of stock RNS/LXMF applications struggle with.
steveplays
Good write-up, Zenith. One thing: why clamp the bitrate of communication channels to a minimum of 50 bits/s instead of 5 bits/s?
According to the manual and API reference, 5 bits/s communication channels are also valid (albeit slow):
Very low bandwidth requirements
  • Reticulum should be able to function reliably over links with a transmission capacity as low as 5 bits per second.
It is important to note that Reticulum is designed to be usable on more or less any computing device, and over more or less any medium that allows you to send and receive data, which satisfies some very low minimum requirements.
The communication channel must support at least half-duplex operation, and provide an average throughput of 5 bits per second or greater, and supports a physical layer MTU of 500 bytes.
MINIMUM_BITRATE = 5
Minimum bitrate required across a medium for Reticulum to be able to successfully establish links. Currently 5 bits per second.
MINIMUM_BITRATE = 5
I know that the API and manual define the usable bitrate as 5 bps, but the idea behind the 50 bps clamp was for interfaces that were advertising broken bitrates. I think if you are anticipating bitrates that low it is much better to use callbacks versus fixed timeouts. This mostly refers to stuff that is synchronous like Nomad page downloading or rncp
In the example I gave above the timeout for a 5 bps path request would be 778 seconds. If say a interface like an RNode was reporting something weird like 8 bps or someones CustomInterface might have done that (I may or may not have had a bug for something I wrote lol) your cold path request timeout is now 12 minutes. At 50 bps the max ceiling is 86.8 seconds
steveplays
Wouldn't a 12 minute timeout be acceptable if the user is aware of the timeout length?
I understand that 12 minutes for a cold path request timeout is long, but 5 bits/s is still a valid communication channel. If interfaces are reporting broken/incorrect low bitrates, shouldn't that be fixed on the interface's side, ideally?
If a node consistently incorrectly reports its own interface bitrates, that node could simply be blackholed
Sounds like a good idea. It would be nice to have a visual indicator of the expected timeout window, especially if we're talking minutes. And if it succeeds right away, you're rewarded with a small dopamine hit.
This isn't just an issue with the application end either. I did a lot of testing and this is a problem inherit to RNS's core Transport.py
I don't know what the best solution on that end is, but right now, below a certain bps threshold, cold path requests are impossible.
The default timeout is 15 seconds, same as it was in the applications above. Below 150 bps a 1-hop RTT is 16.2 seconds. That is something like a slow HF link or LoRa SF/12 BW62.5
PATH_REQUEST_TIMEOUT = 15 # Default timeout for client path requests in seconds
Transport.py:79
What makes this especially bad over slow bps + RF channels is if a single link fails, the path is dropped entirely. Imagine something like a VHF radio or an HF link where there can occasionally be link failures. Unless an announce or cached packet is known, it's pretty much impossible to reach the other end IF this something like the slow 'last mile'
RNS.log("Attempting to discover unknown path to "+RNS.prettyhexrep(destination_hash)+" on behalf of path request"+interface_str, RNS.LOG_PATHING) if RNS.sl(RNS.LOG_PATHING) else None
pr_entry = { "destination_hash": destination_hash, "timeout": time.time()+Transport.PATH_REQUEST_TIMEOUT, "requesting_interface": attached_interface }
with Transport.discovery_pr_lock: Transport.discovery_path_requests[destination_hash] = pr_entry
Transport.py:3123
Any thoughts on this? I may be missing something here.....
Makes a lot of sense for fast mediums, not so much for slower ones.
Couldn't RNS use the bitrate option of interfaces to calculate the timeout for path requests?
The bitrate option configures the interface bitrate. Reticulum will use interface speeds reported by hardware, or try to guess a suitable rate when the hardware doesn’t report any. In most cases, the automatically found rate should be sufficient, but it can be configured by using the bitrate option, to set the interface speed in bits per second.
https://reticulum.network/manual/interfaces.html#common-interface-options
It's both automatically found/guessed and possible to override.
Yes, that's what the application-side change for the first hop builds on in the OP.
This is what my proposal is for the Transport level logic (pastebin in case it loads funky on Nomad: https://pastebin.com/dTSqTagN)
diff --git a/RNS/Transport.py b/RNS/Transport.py
index 1453f78d..0af962da 100755
--- a/RNS/Transport.py
+++ b/RNS/Transport.py
@@ -3119,9 +3119,20 @@ class Transport:
                     return
                 # Forward path request on all interfaces
-                # except the requestor interface
+                # except the requestor interface.
+                # The discovery timeout must also cover a full round trip for an MTU on the slowest interface
+                discovery_timeout = Transport.PATH_REQUEST_TIMEOUT
+                for interface in Transport.interfaces:
+                    if search_mode_filter and not interface.mode in search_mode_filter: continue
+                    if not interface.online or interface == attached_interface: continue
+                    if interface.bitrate != None and interface.bitrate > 0:
+                        medium_timeout = 2*(RNS.Reticulum.MTU*8/max(interface.bitrate, RNS.Reticulum.MINIMUM_BITRATE)) + Transport.PATH_REQUEST_GRACE
+                        if medium_timeout > discovery_timeout: discovery_timeout = medium_timeout
-                pr_entry = { "destination_hash": destination_hash, "timeout": time.time()+Transport.PATH_REQUEST_TIMEOUT, "requesting_interface": attached_interface }
+                pr_entry = { "destination_hash": destination_hash, "timeout": time.time()+discovery_timeout, "requesting_interface": attached_interface }
Reticulum already computes link establishment timeout based on what the interface advertises as the bitrate and the RTT, or what you manually specify as the bitrate.
But cold path requests on the first try use the fixed 15 second window. The change above keeps 15 seconds as the floor for any interface faster than >550 bps, but uses a timeout computed by the slowest interface the path request is going out over
It may be a good idea to also compute PATH_REQUEST_GRACE here using something similar too.
Also Transport.py:1641-1643 has things flipped for extra_link_proof_timeout. I swear I remember this being the other way around, but somehow it got flipped.
                            if packet.packet_type == RNS.Packet.LINKREQUEST:
                                now = time.time()
                                proof_timeout  = Transport.extra_link_proof_timeout(packet.receiving_interface)
                                proof_timeout += now + RNS.Link.ESTABLISHMENT_TIMEOUT_PER_HOP * max(1, remaining_hops)
extra_link_proof_timeout should be using the outbound! interface like:
proof_timeout = Transport.extra_link_proof_timeout(outbound_interface)
My bad, I thought it was done by the app. Anyway, your proposal makes sense to me, seems like something RNS should be able to handle better with the information it has.
ZenithNNTCP 6710c14d306c4820...
I have my changes running on my public-facing Transport instance with some sim-interfaces that are 50, 100, and 300 bps, and then backbone connections. All running smooth.
You can find my changes also available on my rngit Reticulum branch "slow" here: rns://4cf8a0651c4d73cacd0f93ac1d95e80a/public/Reticulum
and on Github:
https://github.com/RFnexus/Reticulum/tree/slow
edited #12
I don't think this solves all asymmetry though. Helps a lot for first hop cold path requests. But there are still topologies where this patch alone doesn't work and one hop must have an intermediary in their path table.
Wondering if anyone else wants to throw their hat in the ring. There may be a more elegant solution but I just haven't thought of one yet.
I should also give a little more context to the problem:
THe idea is to have two, very slow peers reachable by each other, and two slow peers (100~ bps) reachable by a intermediary fast TCP hop. This all works fine as long as all announces are known. It is just a problem when they are not. And a 20% announce cap on a very slow interface complicates this at least from over the air testing.
On a shared medium like the RF spectrum, we often times have other users on the same channel. The gross throughput of something like a packet modem or LoRa radio might be 600 bps, but when the channel is saturated, we have to wait our turn. This all factors into our bitrate and brings the overall bitrate down.
The interface for my project modem73 https://github.com/RFnexus/modem73interface handles this by tracking channel occupancy through presence tones and sync detection and computing what the net bitrate is after the CSMA overhead dynamically.
Reticulum really starts to degrade below 550 bps. Path requests and hop timeouts have razor-thin margins as in the problem demonstrated above and there are asymmetries going over mixed topology. The link establishment timeout is usually very accurate, but it conflicts with other hard-coded timeouts like the path requests, and the computed link window doesn't matter if applications ignore it which is what needs to be fixed mainly. (On the application end not in RNS itself)
