NomadNet 1.3.0 Released
This one is another pretty massive update, courtesy of Zenith, who has been on an absolute tear. The node and interface administration side of nomadnet has gotten a thorough overhaul, with a visual config editor, interface profiles, a built-in Micron page editor and a whole new utilities screen. Conversations have gained easy delivery mode switching, per-message signal stats and a few new conveniences. Micron now has collapsible sections and multi-row form inputs, and we even managed to fix a bug or two!
Changes
  • Added a built-in Micron page editor under [ My Node ], with syntax highlighting, snippets, search and live preview, by Zenith
  • Added page and folder access permission editing to the page editor, by Zenith
  • Added nestable collapsible section folding to Micron, by Zenith
  • Added multi-row form input fields to Micron, by Zenith
  • Added interface profiles, for saving and switching between sets of enabled interfaces, by Zenith
  • Added grid view mode for the interfaces list, by Zenith
  • Added bulk enable, disable, invert and solo actions to the interfaces screen, by Zenith
  • Added filtering of the interfaces list by enabled or disabled state, by Zenith
  • Added Ctrl + O shortcut for toggling the selected interface on or off directly, replacing the enable dialog, by Zenith
  • Added option to paste in interface configuration blocks, by Zenith
  • Added option to open the Reticulum config file in an external editor from the interfaces screen, by Zenith
  • Added announce rate, connection speed and interface mode to interface stats, by Zenith
  • Added restart-required indicator when interfaces have been modified, by Zenith
  • Added a visual configuration editor for all NomadNet and Reticulum config sections, by Zenith
  • Added an optional utilities screen with path tables, a path resolver, probe, identity resolver, rncp file sending and a speed test, by Zenith
  • Added a quit confirmation dialog, by Zenith
  • Added quick delivery option switching to conversations, by Zenith
  • Added Ctrl + V shortcut for cycling conversation delivery method, by Zenith
  • Added per-message details view with delivery method, state and signal stats, by Zenith
  • Added signal stats persistence for received messages, by Zenith
  • Added ability to cancel pending outbound messages with Ctrl+K, by Zenith
  • Added node destination QR dialog and page editor shortcut to node info, by Zenith
  • Added node online indicator to local peer info, by Zenith
  • Added Guide sections on interface profiles and collapsible Micron sections, with jump links for all interface types, by Zenith
  • Improved Micron form fields to shrink to fit narrow terminals instead of being hidden, by Zenith
  • Improved conversation view to display the selected delivery method, by Zenith
  • Fixed conversation editor not re-enabling when a peer becomes known, by Zenith
  • Fixed directory entries for node operators being remembered under the node hash instead of the operator address, by Zenith
There's a lot of new stuff here, so if you find any bugs or weirdness, this thread is a good place to post them.
p1ld7a b2e101f8b8d8c776...
Cool changelog thanks !!! I will definitely try it and package it on Nix as soon as it is available on Pypi or Github.
It's up on pypi now as well :)
Zenith
Hey Mark, I sent you a .patch addressing one security issue and a few other minor issues to your LXMF. I had meant to put them on my branch, but you merged the new features in before I could do it lol.
Haven't gotten it yet Zenith, can you try sending it again? Have my clients open now, so you can reach me directly without having to go PN.
It's out :) Thanks Zenith.
You probably want to bump that to 1.3.1 already @p1ld7a ;)
steveplays daf042c1c000a24b...
Mark, what are your thoughts on adding discovered interfaces to the interfaces list?
Maybe they should have their own page though, because I made a small patch to load them into the existing page (replacing config interfaces) to try it out, but they cause the page to take ~700 ms to load for me with 388 interfaces
(~~300 ms without sorting by name, ~~700 ms with sorting by name)
I suppose (probably; I didn't check) most of the ~300 ms is spent reading the files of the discovered interfaces in InterfaceDiscovery.list_discovered_interfaces()
diff --git a/nomadnet/ui/textui/Interfaces.py b/nomadnet/ui/textui/Interfaces.py
index b3914ef..392f674 100644
--- a/nomadnet/ui/textui/Interfaces.py
+++ b/nomadnet/ui/textui/Interfaces.py
@@ -3823,10 +3823,11 @@ class InterfaceDisplay:
     def _build_interface_items(self):
         self.interface_items = []
         self.interface_tiles = []
-        interfaces = self.app.rns.config['interfaces']
+        interfaces = sorted(self.app.rns.discovered_interfaces(), key=lambda discovered_interface: discovered_interface["name"])
         processed_interfaces = {}
-        for interface_name, interface in interfaces.items():
+        for interface in interfaces:
+            interface_name = interface["name"]
             interface_data = interface.copy()
             if interface_data.get("type") == "RNodeMultiInterface":
If you want, I could make a proper patch with a new page.
