Can confirm, I do this myself occasionally. There are a number of caveats with this, but it's very doable.
First, since you mentioned disaster relief, I have to wonder what useful information you would be wanting from an LLM that is reliable in a disaster. Small models that run locally tend to, in my experience, confabulate more than larger models. Give it a harness with access to a local copy of wikipedia and maybe you'd fare better, but I'd certainly make sure there is an actual LLM + harness combo that solves your problem before investing in anything. Power is another consideration; the halo strix machines usually run around 100-110W during inference, which is significantly less than a GPU setup, but still quite power hungry if you're running on batteries.
Now, if the use case was just hypothetical and you just want to see an LLM respond over LXMF for the fun of it, regardless of the quality or capabilities, there are a number of ways to get there, but I will share my setup.
I have a headless VM running hermes agent, which supports a bunch of different message platforms: https://hermes-agent.nousresearch.com/docs/user-guide/messaging/signal for example. There are several harnesses out there that have this abstraction, but the key thing is that it has some support for plugins and adding your own messaging platform. OpenClaw and Letta (and I'm sure others that I haven't heard of) do this too. You could write your own harness, but that's a lot more work than plugging into one that already has the basics covered and is designed to be extended.
Hermes is then configured to call out (over http in my lan) to my personal inference server. This doesn't have to be on two separate machines, but I want all the RAM on one machine for the model itself, and having this separation additionally allows isolating the inference server from the internet, for example. Granted, the VM running the agent harness is arguably a more important thing to isolate from the internet, but given the recent explosion of customized inference engines for various models and hardware (vs. just a few months ago when there was really only llama.cpp and vLLM), I run each model (one at a time) in its own container, and proxy everything through llama-swap, which manages the container life cycle and swaps which model is active when it receives an API request for said model. It even has as nice web ui with performance dashboards and such.
Anyway, as for the frontend, you can use your messaging app itself, the hermes cli or tui, or I think they even have a web ui and desktop app nowadays. This is something that is going to vary a lot over time, and depends on which harness you choose. This also of course gets to your main question, contacting said agent over Reticulum.
A while back, I had hermes + deepseek v4.1 flash running locally write a plugin for hermes to add LXMF as a messaging platform. It takes config for allowed LXMF destinations and drops others, and validates the signature matches upon receipt. It also manages its own instance of rnsd. Once you have the LXMF -> agent harness wired, everything else pre-existing falls into place. Your harness calls your LLM, and your LXM gets to the harness however it can via reticulum.
So the whole flow end to end for me here is:
Columba/LXMF -> (reticulum network) -> hermes LXMF adapter -> (HTTP on LAN) -> llama-swap -> inference engine
Vision is a capability of specific LLMs and is not universally supported at the model level, but hermes does support it, so as long as you run a model with vision capabilities and wire up the LXMF image attachment fields you're all set. You can also use a speech to text (STT) model and send it voice attachments, and though the model doesn't have native audio support (usually at least; I heard the latest Google model actually does), it'll receive the text your STT model outputs.
Models love to output markdown, so a while back I added a markdown rendering mode to Columba to make it easier to read. Though, I still need to get around to adding a copy button for the code blocks it outputs... there's always something :)
Hopefully this gives you some ideas for how you can deploy and connect these things. But I do have to stress that simply answering questions where facts and truth matter, directly from the knowledge baked into the weights of the model, is not reliable and shouldn't be trusted, at least in 2026. You could explore RAG or other memory techniques to improve fact retrieval in specific domains, but that's a whole other topic :)
