RAK Wismesh TAG support ?
Started by p1ld7a ·
yes it does work. try flashing with Columba RAk4631. Not sure about GPS.
Thanks,
By "flashing with Columba RAK4631", you hint that I have to flash using Bluetooth ?
On a side note, I have been looking around and I haven't found any support for Wismesh Tag.
I will probably try in the upcoming days and report back.
p1ld7a 8279b6a997b08071...
I tested:
rnodeconf --autoinstall
Here's the log:
                               Installer Ready
Ok, that should be all the information we need. Please confirm the following
summary before proceeding. In the next step, the device will be flashed and
provisioned, so make sure that you are satisfied with your choices.
Serial port     : /dev/ttyACM0
Device type     : RAK4631 779 - 928 MHz
Platform        : NRF52
Device MCU      : Nordic Semiconductor nRF52840
Firmware file   : rnode_firmware_rak4631.zip
Is the above correct? [y/N] y
[18:47:03] Checking firmware file availability...
[18:47:04] The selected firmware for this board is version 1.86
[18:47:04] Using existing firmware file: rnode_firmware_rak4631.zip for version 1.86
[18:47:04] Verifying firmware integrity...
[18:47:05] Decompressing firmware...
[18:47:05] Firmware decompressed
[18:47:05] Flashing RNode firmware to device on /dev/ttyACM0
Upgrading target on /dev/ttyACM0 with DFU package /home/pol/.config/rnodeconf/update/1.86/rnode_firmware_rak4631.zip. Flow control is disabled, Dual bank, Touch 1200
Activating new firmware
Device programmed.
[18:47:33] Done flashing
[18:47:33] Waiting for NRF52 reset...
[18:47:39] Opening serial port /dev/ttyACM0...
[18:47:43] Device connected
[18:47:43] Current firmware version: 1.86
[18:47:43] Reading EEPROM...
[18:47:43] Clearing old EEPROM, this will take about 15 seconds...
[18:48:06] Waiting for NRF52 reset...
[18:48:24] Loading signing key...
[18:48:24] Bootstrapping device EEPROM...
[18:48:56] EEPROM written! Validating...
[18:48:56] Setting firmware checksum...
[18:48:58] Waiting for NRF52 reset...
[18:49:19] Could not download EEPROM from device. Is a valid firmware installed?
It got stuck at [18:49:19] Could not download EEPROM from device. Is a valid firmware installed?, do you know what I could do to fix this and get a successful install ?
After retrying a couple of times, it worked successfully. I am super happy !
xf302 f4f0dd21c715f082...
nice! does gps actually work? I haven't tried Reticulum with an Rnode device yet, I'm curious how close we are to feature parity with Meshtastic/Meshcore.
