[RNS 1.2.5] InterfaceAnnouncer.sanitize() crashes with AttributeError when reachable_on or discovery_name is None
Discussion Help
Started by PAzter1101 ·
Running RNS 1.2.5 with a config that doesn't set reachable_on on my local TCPServerInterface — the discovery thread crashes every JOB_INTERVAL with:
[Error] Error while preparing interface discovery announces: 'NoneType' object has no attribute 'replace'
[Error] An unhandled <class 'AttributeError'> exception occurred: 'NoneType' object has no attribute 'replace'
Traceback (most recent call last):
  File ".../RNS/Discovery.py", line 78, in job
    app_data = self.get_interface_announce_data(selected_interface)
  File ".../RNS/Discovery.py", line 114, in get_interface_announce_data
    reachable_on = self.sanitize(interface.reachable_on)
  File ".../RNS/Discovery.py", line 89, in sanitize
    sanitized = in_str.replace("\n", "")
AttributeError: 'NoneType' object has no attribute 'replace'
The discovery announce never goes out.
Root cause
InterfaceAnnouncer.sanitize calls in_str.replace("\n", "") without a None-check. It is invoked against interface.discovery_name (line 104) and interface.reachable_on (line 114), both of which can legitimately be None on an interface whose operator didn't set them in the config. The sibling helper InterfaceAnnouncer.sanitize_name (line 204) already early-outs on falsy input: if not name: return None.
Patch
     def sanitize(self, in_str):
+        if in_str is None: return None
         sanitized = sanitized.replace("\r", "")
         sanitized = sanitized.strip()
         return sanitized
Downstream callers already cope with a None return — the non-windows reachable_on branch wraps the subsequent os.path.expanduser in try/except and aborts the announce cleanly, and missing fields are simply omitted from the announce payload. Net behaviour: that one announce is skipped, the discovery thread keeps running.
Branch with the fix + regression test
Since the upstream repo doesn't accept external PRs/Issues/Discussions, I put the change on a fork — one-line fix plus a small tests/discovery.py regression test that bypasses the heavy InterfaceAnnouncer.__init__ via __new__:
https://github.com/markqvist/Reticulum/compare/master...PAzter1101:fix/discovery-sanitize-none-input
Happy to send the patch in whatever form is easiest if a fork-branch link is inconvenient.
Thanks PAzter1101. Verified and patched in:
c86b9c97032f1ffeeeb8d02b43faae8c321aff93
Will be released shortly.
Thanks Mark — great turnaround. Will pick it up once the next release lands on the public mirror.
It's out on pip now
daylight-hub
Can you give clear instructions how to use rngit? What testnet do I have to be connected to, any special configurations in the config file, what exact command to download and install the latest version? I'm currently on RNS 1.2.5.
