RNS 1.5.0 - Protocol Violation Control
The upcoming release of RNS 1.5.0 will introduce per-interface protocol violation tracking and control. This means, that going forward, it will be a lot easier to handle broken implementations and clients doing things that no sane implementation would do. For example, protocol violations include:
  • Sending announces that are cryptographically invalid
  • Forwarding meaningless link requests
  • Transporting completely malformed packets
  • Ignoring negotiated link MTUs
  • Dumping random data at 35 Mbps to bogus links
  • And all kinds of other "fun", but meaningless stuff
This will also make testing things much easier, since protocol violation stats can be viewed live per interface with rnstatus.
Since nothing is perfect, and there's bound to be both some false hits and missed cases initially, the actual control part of this will not be enabled by default in 1.5.0. But if everything works out nicely, it will be the default behavior (on interface types where this makes sense, BackboneInterface for example) from 1.5.1 to instantly tear down excessively violating clients, and potentially block their IP for a period of time. All configurable of course, so you decide how to use this.
And while RNS itself does correctly drop packets with invalid hop counts if received, before 1.5.0, it does actually allow constructing and sending them, so I'm officially the OG Protocol Violator here ;)
