This release brings yet another round of major efficiency, performance and filtering improvements to RNS, and continues the transition towards full network stamp functionality.
All network stamp types will now be generated and emitted by default. Expect some CPU load once your applications start up for the first time on 1.6.1, as destination stamps are generated.
Changes
- Enabled network stamp generation by default
- Added ability to filter destination types by hash
- Added hop limiter options both globally and per-interface
- Added super fast announce ingress pre-filtering
- Added filtered traffic stats to
rnstatus - Added link traffic stats to
rnstatus - Added display of remote transport IDs per client interface in
rnstatus. - Ability to inspect filtered traffic, announces, et cetera in
rnstatusper interface - Ability to inspect tunnel properties, stamp costs, remote implementation info and more in
rnstatus - Added ability to set
client_limitonBackboneInterface, defaults to 500 - Added ability to configure the maximum amount of stamp workers and worker niceness
- Added ability to place a
blocked_ipsfile in your config directory to permanently block IPs - Added ability to directly blackhole remote transport nodes
- Added ability to configure stamp values and costs for
rngit - Added asynchronous, interleaved held announce queue cleaning across all interfaces based on potential announce usability
- Added bidirectional tunnel synthesis on non shared-medium interfaces, with stamp cost and version signalling
- Added announce rate table persistence between instance restarts
- Added default caps for configured auto-connect interface counts
- Added path state info to API path table getters
- Significantly optimized and improved inbound announce filtering and deduplication
- Significantly optimized and reworked the filtering subsystem for scalability across hundreds of interfaces
- Improved
rnpathdisplay and filtering options - Improved traffic counting
- Improved path responsiveness tracking
- Improved protocol violation tracking and logging
- Improved path pool and tunnel table culling
- Tuned announce validation caches and other parameters
- Fixed a regression introduced in
1.6.0, that could cause path table culling to temporarily remove an instance's own local destination paths - Fixed dataplane egress control state not resetting on
BackboneInterfaceclient connection recovery - Fixed a potential logging deadlock
- Fixed a potential exit handler deadlock if a signal arrives mid RPC call
- Fixed missing wanted destination type for interface discovery when local announce filtering was enabled
- Fixed split-instance initial known-destinations load not being available on Android
- Added mitigation for a CPython process fork deadlock dug in stdin handling
