â—ˆ 9ce92808be498e9e05590ff27cbfdfe4
RRC hub - 28c7c1a68c735693aa8e6b8193ed44b2
Started by Zenith ·
i'm having issues connecting, but meshchatx is reporting a found path, are we sure that the chat is up yet?
Ivan 7cc8d66b4f6a0e0e...
MeshChatX does not support RRC protocol (yet) you need a separate RRC client.
kc1awv 0d33923fcd15d628...
Just be aware, the RRC clients I wrote are alpha stage - I welcome PRs for bug fix / features if you're so inclined!
VERY NICE! I like it :)
Alledegly_noderunner 2a323a0ad8734e73...
Left the RRC TUI up over night on my machine but nothing came up on the dicovery page? are you announcing that address? it picked up Torlando's RRC server and a few others but not rns.recipes.
NomadNet 1.1.0 now has a built in RRC client and [ Channels ] tab!
x2tyfi ccf53a936676f008...
Any idea if this is on roadmap?
Yes for v4.7.0
That's awesome news Ivan! Thanks for all your work.
Rob
I might be missing something, so let me ask. I built a RRC feature into my mobile app and it works, but the connection drops. I know there is a Ping/Pong check that makes the client timeout if no response. Is the intent that the client always responds to the keepalive or is the intent that the client only connects when one wants to chat? Thanks! BTW, right now it shows no destination, so I can connect anyway.
I've been trying to use RRC on nomadnet 1.2.0 in ubuntu but it just closes nomadnet immediately if I try and view a channel.
Zenith 06ddae88c732079d...
edited #13
Can you share what it says in ~/.nomadnetwork/logfile ? And also try pip install -U nomadnet to make sure you are on the latest release, which is currently 1.2.1
Anonymous 9f7ba7032eb49009...
Yeah I am actually running 1.2.1. Thanks for your time and all your work.
Here is the error log:
[2026-05-24 16:53:03] [Error] An unhandled exception occurred, the details of which will be dumped below
[2026-05-24 16:53:03] [Error] Type : <class 'TypeError'>
[2026-05-24 16:53:03] [Error] Value : from_bytes() missing required argument 'byteorder' (pos 2)
[2026-05-24 16:53:03] [Error] Trace :
File "/home/REDACTED/.local/bin/nomadnet", line 8, in <module>
sys.exit(main())
File "/home/REDACTED/.local/lib/python3.10/site-packages/nomadnet/nomadnet.py", line 51, in main
program_setup(configarg, rnsconfigarg, daemon, console)
File "/home/REDACTED/.local/lib/python3.10/site-packages/nomadnet/nomadnet.py", line 11, in program_setup
app = nomadnet.NomadNetworkApp(
File "/home/REDACTED/.local/lib/python3.10/site-packages/nomadnet/NomadNetworkApp.py", line 442, in init
nomadnet.ui.spawn(self.uimode)
File "/home/REDACTED/.local/lib/python3.10/site-packages/nomadnet/ui/init.py", line 33, in spawn
return TextUI()
File "/home/REDACTED/.local/lib/python3.10/site-packages/nomadnet/ui/TextUI.py", line 252, in init
self.loop.run()
File "/home/REDACTED/.local/lib/python3.10/site-packages/urwid/event_loop/main_loop.py", line 318, in run
self._run()
File "/home/REDACTED/.local/lib/python3.10/site-packages/urwid/event_loop/main_loop.py", line 420, in _run
self.event_loop.run()
File "/home/REDACTED/.local/lib/python3.10/site-packages/urwid/event_loop/select_loop.py", line 182, in run
self._loop()
File "/home/REDACTED/.local/lib/python3.10/site-packages/urwid/event_loop/select_loop.py", line 229, in _loop
record.data()
File "/home/REDACTED/.local/lib/python3.10/site-packages/urwid/display/_posix_raw_display.py", line 285, in wrapper
return self.parse_input(event_loop, callback, self.get_available_raw_input())
File "/home/REDACTED/.local/lib/python3.10/site-packages/urwid/display/_raw_display_base.py", line 492, in parse_input
callback(decoded_codes, raw_codes)
File "/home/REDACTED/.local/lib/python3.10/site-packages/urwid/event_loop/main_loop.py", line 445, in _update
self.process_input(keys)
File "/home/REDACTED/.local/lib/python3.10/site-packages/urwid/event_loop/main_loop.py", line 549, in process_input
if hasattr(self._topmost_widget, "mouse_event") and self._topmost_widget.mouse_event(
File "/home/REDACTED/.local/lib/python3.10/site-packages/nomadnet/ui/textui/Main.py", line 78, in mouse_event
return super(MainFrame, self).mouse_event(size, event, button, col, row, focus)
File "/home/REDACTED/.local/lib/python3.10/site-packages/urwid/widget/frame.py", line 558, in mouse_event
return self.body.mouse_event((maxcol, maxrow - htrim - ftrim), event, button, col, row - htrim, focus)
File "/home/REDACTED/.local/lib/python3.10/site-packages/urwid/widget/columns.py", line 1101, in mouse_event
return w.mouse_event(w_size, event, button, col - x, row, focus)
File "/home/REDACTED/.local/lib/python3.10/site-packages/nomadnet/ui/textui/Channels.py", line 321, in mouse_event
return super().mouse_event(size, event, button, col, row, focus)
File "/home/REDACTED/.local/lib/python3.10/site-packages/urwid/widget/pile.py", line 1025, in mouse_event
return w.mouse_event(w_size, event, button, col, target_row, focus and self.focus == w)
File "/home/REDACTED/.local/lib/python3.10/site-packages/urwid/widget/filler.py", line 320, in mouse_event
return self._original_widget.mouse_event((maxcol, maxrow - top - bottom), event, button, col, row - top, focus)
File "/home/REDACTED/.local/lib/python3.10/site-packages/nomadnet/vendor/additional_urwid_widgets/widgets/indicative_listbox.py", line 267, in mouse_event
result = self._listbox.mouse_event(modified_size, event, button, col, (row - topBar_rows), focus)
File "/home/REDACTED/.local/lib/python3.10/site-packages/urwid/widget/listbox.py", line 1907, in mouse_event
if w.mouse_event((maxcol,), event, button, col, row - wrow, focus):
File "/home/REDACTED/.local/lib/python3.10/site-packages/nomadnet/ui/textui/Channels.py", line 224, in mouse_event
self._emit("click")
File "/home/REDACTED/.local/lib/python3.10/site-packages/urwid/widget/widget.py", line 310, in _emit
signals.emit_signal(self, name, self, *args)
File "/home/REDACTED/.local/lib/python3.10/site-packages/urwid/signals.py", line 291, in emit
result |= self._call_callback(callback, user_arg, weak_args, user_args, args)
File "/home/REDACTED/.local/lib/python3.10/site-packages/urwid/signals.py", line 314, in _call_callback
return bool(callback(*args))
File "/home/REDACTED/.local/lib/python3.10/site-packages/nomadnet/ui/textui/Channels.py", line 1691, in _select_room
self._show_room(hub, room)
File "/home/REDACTED/.local/lib/python3.10/site-packages/nomadnet/ui/textui/Channels.py", line 1799, in _show_room
widget = RoomWidget(self, hub, room)
File "/home/REDACTED/.local/lib/python3.10/site-packages/nomadnet/ui/textui/Channels.py", line 586, in init
self.update_messages()
File "/home/REDACTED/.local/lib/python3.10/site-packages/nomadnet/ui/textui/Channels.py", line 749, in update_messages
widgets.append(_message_widget(self.app, self.hub, self.room, m, link_delegate=self.link_delegate))
File "/home/REDACTED/.local/lib/python3.10/site-packages/nomadnet/ui/textui/Channels.py", line 1372, in _message_widget
if app.rrc_nick_colors: nick_attr = f"`FT{get_nick_color(m.src, t, app)}"
File "/home/REDACTED/.local/lib/python3.10/site-packages/nomadnet/ui/textui/Channels.py", line 1235, in get_nick_color
return nick_colors[(int.from_bytes(sender_hash)+shift)%len(nick_colors)]
There is a new release on pypi that fixes that issue for Python 3.10. Upgrade your nomadnet and it should be working now
that worked thanks
Hi, I am having constant issues with staying connected. After some time I am disconnected and am simply unable to reconnect. This gets better after some time. It feels like some fail2ban thing thats blocking connections from my uplink backbone node, as I had the same issue with another client using the same initial backbone connection. Is something like this active?
nLupo 38db8840e3b89294...
#18
Nice place. It's my first time I meaningfully have used RRC and I love it.
edited #19
@zenith I think 28c7c1a68c735693aa8e6b8193ed44b2 is buggy, but I can't articulate exactly how (sorry). Initially I though it was a 'me' problem, then a client problem, but even today I saw people on other RCC hubs saying 28c7c1a68c735693aa8e6b8193ed44b2 is either empty or impossible to connect to. It's a shame because on matrix etc, it's listed as the 'official' RCC hub, and its the largest hub (60+ people).
I'm genuinely curious as to what's goin on here, because I connected to all other running hubs without issue (around 80ish).
Roughly speaking:
About 2-3 weeks ago I used MCX to connect to it, no dice. I tried nomadnet, no dice. I tried ratspeak, no dice.
Eventually in the last 2 week I was able to connect to the hub with nomadnet and MCX clients (I don't know what changed) but it still behaves differently from the other hubs.
a) the channel list doesn't auto-appear in MCX, making it look entirely empty. It's the only hub that does that.
b) general is not auto-joined on MCX either (probably because its' not found)
I believed it was a client thing and raised it with MCX, but I saw today in other hubs people saying Colorado Mesh-client can't connect to it either.
I realize this is totally crap as a bug report and I'm sorry, but I don't know how to debug this further. I want to help What server is it running? the kc1awv one? I could try spooling up the same software and see if throw all my clients at it to see if it connects.
update: zevaryx (author of rettui) says he gets "No public rooms on this hub; /join <name> to create one", using https://github.com/zevaryx/rettui. quote: "It does list the channels though, and says to use /join to join them"
edited #20
I ran into the channel listing issue a few weeks ago and fixed it in my eridanus client. The issue was the string format changes from rrcd when the channel list notice is larger than the link MDU https://github.com/kc1awv/rrcd/blob/main/rrcd/messages.py#L77
So afaik yes it is a client issue, but most hubs don't (or didn't, at least) exceed this until somewhat recently.
