Hello @CryMan
Can you see what is actually sending announces every minute? As in, is it a destination on your own node doing this, for example an application running there? Or is it simply that you see other announces from the network being rebroadcasted over your node?
If it's some application on your device sending announces every minute, that is indeed excessive. But clients should not just announce every minute, most will have sensible defaults configured, such as once every four to six hours or so, if left unattended.
If you're just seeing announces getting relayed, that is normal though.
Since that config is from an older version, you could improve the interfaces section like the following:
[interfaces]
[[Default Interface]]
type = AutoInterface
enabled = Yes
mode = internal
[[R-MAP World]]
type = BackboneInterface
mode = boundary
port = 4242
target_host = rmap.world
announce_rate_target = 7200
announce_rate_penalty = 300
announce_rate_grace = 3
[[rns_lt_usa_ip]]
mode = boundary
remote = 199.244.51.59
target_port = 4242
transport_identity = fdcac00a6afc45e17e3159df08653315
```ini
That assumes your `AutoInterface` is your own, internal network, and you don't want all the announces from the wider backbone net flooding in all the time. If you actually *do* want that, you can can set `announces_to_internal = yes` on one or both of your outgoing backbone connections. In either case, clients on the local network can still request and get paths to the entire wider connected network through your two backbone connections.
The announce rate targets up there are 2 hours, which means you will only see one new announce at most for each individual destination every 2 hours. You can raise this if you want, 4-6 hours may even be more close to what you want, with the amount of destinations being created on the network at the moment.
First of all, Mark, I’d like to express my sincere gratitude for your project, Reticulum—and especially for the "Zen of Reticulum," which resonates deeply with me.
I tried adding some lines to the config, but it didn’t help. Let me provide more details about the structure; perhaps the nuances lie there.
I am running a virtual machine in the cloud, which hosts a Docker container containing rnsd and rnsd-node-page. Here is its current configuration. As you can see, there is actually an additional private interface (I didn’t think it was relevant).
[interfaces]
# This interface enables communication with other
# link-local Reticulum nodes over UDP. It does not
# need any functional IP infrastructure like routers
# or DHCP servers, but will require that at least link-
# local IPv6 is enabled in your operating system, which
# should be enabled by default in almost any OS. See
# the Reticulum Manual for more configuration options.
enabled = Yes
[[TCP Server Interface]]
type = TCPServerInterface
mode = gateway
listen_ip = 0.0.0.0
listen_port = 4242
network_name = private
passphrase = <hidden>
[[R-MAP World]]
mode = boundary
port = 4242
#announce_rate_target = 3600
#announce_rate_penalty = 3600
#announce_rate_grace = 12
[[rns_lt_usa_ip]]
mode = boundary
target_port = 4242
Additionally, I have another node on my home network running NomadNet, which is connected to this cloud-based node.
[interfaces]
[[Home]]
enabled = true
mode = gateway
listen_ip = 0.0.0.0
listen_port = 4242
[[MBC]]
type = TCPClientInterface
enabled = true
target_host = <hidden>
target_port = 4242
[[Central_Belfast_I2P]]
type = I2PInterface
peers = loj5ofd3a5b5suefcrasn5cnidgofeftnpnko6ym5wkamllrucga.b32.i2p
transport_identity = c7cc7cc76dc3632569b7b84022de11f7
It is on this home-based NomadNet node—specifically under the "Network" -> "Announce Stream" section—that I see my MBC node appear exactly once every minute, alongside other nodes.
