App ecosystem planning
Question Help
Started by Blastertoad ·
I think I understand the basics of rns and setting up nodes, messaging with sideband / meshchat etc.
What i am currently struggling on as I plan projects around rns is planning how multiple clients or apps are to coexist on a system. Let's for instance consider breaking nomad net out to a dedicated browser. Now if a user downloads NomadBrowser, is it going to look for rns running, is rns packaged with it like meshchat so running browser is an rns instance. Or should it be a dependency to download an rns deamon.
When we have browsers, rngit, games, etc. built utilizing rns what is the desired or recommended method here of connecting to or packaging rns. I thinks its a little wasteful for everything to be an instance of rns and need configuring.
Then if you are running a dockerized node, how are apps supposed to use this. Does a game server docker need an rns instance to connect to the node docker? Or a partyline server docker etc.
Shared instances
Nickie fe63e2eeb03bf3da...
https://reticulum.network/manual/using.html
You use a shared instance, they can work both over sockets (default) or via a TCP port. A well-written app will detect a running shared instance and will instead utilize it instead of spawning its own.
adept 2db1af96591ae4eb...
x
x
