Connectivity in my "router net"
Started by Rudi Mentaire 756c9adefd2ed337... ·
One last post for today (and sorry for my ignorance: as I had said, my knowledge around concepts like "port", udp, tcp, low-level functioning of those etc. is limited).
My goal is: get a one hop rnsh link between two Debian laptops connected to the WiFi of our Fritzbox.
My environment: Fritzbox with WLAN, my own laptop, laptop of my girlfriend. rnsd with nearly same config running on both of them, including a (verfified as working!) AutoInterface, among other interfaces, but given a higher then normal gravity. Plus the LineageOS Smartphone of my girlfriend running a sideband apk.
What I see: nomadnet always shows a one-hop lxmf link connection established from each notebook to the smartphone. But the nomadnets only have a 8 hop or 13 hop lxmf router connection established between those devices (and those count values are not even symmetric, but AFAIU this is because links are not symmetric in this case and path resolution comes to different solutions).
So, I would like a 1 hop direct rnsh connection between the laptop (via the Fritzbox), whereby the latencies and lost connections I see suggest that I have rather also a 13 hop connection. Same for rncp.
How can I investigate the "cause", and what would potentially come to mind as a cause? I know how to investigate paths, understand the semantics of my whole reticulum config (at least as good as the manual and some code diving suggests) but there must be something different I am missing. Maybe even something painfully simple (I hope not).
