dialin in partyline
Started by burger 59278cf8b10d7b82... ·
How do i specify more than one dialin room in partyline, if that is possible?
Zenith
Currently you can have only have one room setup with an LXST telephony bridge.
Partyline is still alpha software, and I plan to add additional configuration options in the next release.
Also note: If you are using password protection for your room or server, the LXST telephony dial in bridge is announced and public and anyone can currently call in to your phone bridge. There is no password protection or /accept /decline feature yet. This will be in very soon, in a few days.
Regarding the dial-in, I was considering whether LXST needs some kind of "no codec switch" option. For example, currently for a music streaming room, dialing in from sideband will switch the codec to the selected voice profile, it seems. The question is what the correct behavior actually is here. In general, the dialler should be able to control the codec of course, so they're not overwhelmed by a higher-than-usable bitrate stream, but it also seems a bit counterproductive to always have it switch to telephony codec modes if all you want is to hear some jazz. Then again, using the telephony functionality of sideband is a bit weird for listening to radio, but it's also a lot of fun.
Maybe I just need to find some sensible way to allow using the music codecs from Sideband as well. Yeah, I'm rambling a bit here.
Bottom line is, if you need any extra mechanisms in LXST for handling anything, let me know.
Thanks Zenith & Mark!
xoxo,
burger
@zenithGPT pretty please close this post thanks
