I'd like to push to git on the same machine im hosting rngit, how do i do that?
As it is unable to resolve the address...
Same for nomadnet i cant reach my own nomadpage im hosting on my machine.
Started by falafool 44aada36cb287bc8... ·
It works perfectly fine out of the box. You've got something completely messed up in your configuration setup or something.
Nobody can (or will be willing to) help you when you haven't provided any actual information on your setup, but are simply stating "it's not working".
My guess is that you're using different RNS configs, and the programs can't actually talk to each other, because you accidentally isolated them in different instances. Read the "Using Reticulum on your system" chapter of the manual. It's all explained in there.
hey mark, thanks for letting me know.
Generally i have different isolated instances I thought I might increase anonymity with it, but I'll read up on that more before proceeding.
Thanks for the hints, I'll know where to get started!
