nomadnet message propagation: always "The link to <any prop node> was closed"
Started by Rudi Mentaire 756c9adefd2ed337... ·
I hope I'm not on a wrong track here but something with propagated message sending in nomadnet really seems to be wrong. With any propagation node I try, including those that work well with sideband in the same moment, sending fails. Here is an example log (slightly redacted; always looks very similar):
[2026-09-09 06:52:16] [Verbose] Sending lxmf.delivery announce
[2026-09-09 06:52:35] [Debug] No stamp cost set on LXM to <7e3ecdcaf9c929d0363e9669ea983080>, autoconfigured to None, as required by latest announce
[2026-09-09 06:52:35] [Debug] Deferred stamp generation was requested for <LXMessage>, but outbound ticket was applied, processing immediately
[2026-09-09 06:52:35] [Debug] A ticket for <7e3ecdcaf9c929d0363e9669ea983080> was already delivered 23m and 26.69s ago, not including another ticket yet
[2026-09-09 06:52:35] [Debug] Generated stamp with outbound ticket 2b:c2:a4:42:db:10:8b:47:7a:6a:76:fb:e2:53:11:9e for <LXMessage 9635fbed039d0e0e812de958a125d833e78a60e504e5feebc6e521e56bbd816f>
[2026-09-09 06:52:36] [Debug] Received active propagation node announce from <2ee4eb045b55fa7daba9371393ee283f>
[2026-09-09 06:52:37] [Debug] Starting propagation stamp generation for <LXMessage 9635fbed039d0e0e812de958a125d833e78a60e504e5feebc6e521e56bbd816f>...
[2026-09-09 06:52:37] [Debug] Generating stamp with cost 16 for <caa62fad08b841f37fa22b9dadab9199c03cc5b3ec7512090a6bcf6800dc5ad5>...
[2026-09-09 06:52:37] [Debug] Starting 4 stamp generation workers
[2026-09-09 06:52:52] [Debug] Stamp with value 18 generated in 14.97s, 29808 rounds, 1991 rounds per second
[2026-09-09 06:52:52] [Debug] Generated stamp with outbound ticket 2b:c2:a4:42:db:10:8b:47:7a:6a:76:fb:e2:53:11:9e for <LXMessage 9635fbed039d0e0e812de958a125d833e78a60e504e5feebc6e521e56bbd816f>
[2026-09-09 06:52:52] [Debug] Propagation stamp generation completed for <LXMessage 9635fbed039d0e0e812de958a125d833e78a60e504e5feebc6e521e56bbd816f>
[2026-09-09 06:52:53] [Debug] Outbound processing for <LXMessage 9635fbed039d0e0e812de958a125d833e78a60e504e5feebc6e521e56bbd816f> to <7e3ecdcaf9c929d0363e9669ea983080>
[2026-09-09 06:52:53] [Debug] Attempting propagated delivery for <LXMessage 9635fbed039d0e0e812de958a125d833e78a60e504e5feebc6e521e56bbd816f> to <7e3ecdcaf9c929d0363e9669ea983080>
[2026-09-09 06:52:53] [Debug] No path known for propagation attempt 1 to <c2a469aa5151f67153e54616ef162b0e>. Requesting path...
[2026-09-09 06:52:53] [Debug] Establishing link to <c2a469aa5151f67153e54616ef162b0e> for propagation attempt 2 to <7e3ecdcaf9c929d0363e9669ea983080>
[2026-09-09 06:52:53] [Debug] Signalling link MTU of 262.14 KB for link
[2026-09-09 06:52:53] [Debug] Establishing link with mode AES_256_CBC
[2026-09-09 06:52:53] [Debug] Link request <143eacdb6b43b66a39a025dc00c1476b> sent to <lxmf.propagation.0635238b3f73e75b6706b7346e2b0b61:c2a469aa5151f67153e54616ef162b0e>
[2026-09-09 06:52:54] [Debug] Validating link request proof with mode AES_256_CBC
[2026-09-09 06:52:54] [Debug] Destination confirmed link MTU of 4.10 KB
[2026-09-09 06:52:54] [Debug] Link <143eacdb6b43b66a39a025dc00c1476b> established with <lxmf.propagation.0635238b3f73e75b6706b7346e2b0b61:c2a469aa5151f67153e54616ef162b0e>, RTT is 379ms and 750.97?s
[2026-09-09 06:52:54] [Debug] Outbound processing for <LXMessage 9635fbed039d0e0e812de958a125d833e78a60e504e5feebc6e521e56bbd816f> to <7e3ecdcaf9c929d0363e9669ea983080>
[2026-09-09 06:52:54] [Debug] Attempting propagated delivery for <LXMessage 9635fbed039d0e0e812de958a125d833e78a60e504e5feebc6e521e56bbd816f> to <7e3ecdcaf9c929d0363e9669ea983080>
[2026-09-09 06:52:54] [Debug] Starting propagation transfer of <LXMessage 9635fbed039d0e0e812de958a125d833e78a60e504e5feebc6e521e56bbd816f> to <7e3ecdcaf9c929d0363e9669ea983080> via <c2a469aa5151f67153e54616ef162b0e>
[2026-09-09 06:52:54] [Debug] Set compression support from app data to: True
[2026-09-09 06:52:57] [Debug] Outbound processing for <LXMessage 9635fbed039d0e0e812de958a125d833e78a60e504e5feebc6e521e56bbd816f> to <7e3ecdcaf9c929d0363e9669ea983080>
[2026-09-09 06:52:57] [Debug] Attempting propagated delivery for <LXMessage 9635fbed039d0e0e812de958a125d833e78a60e504e5feebc6e521e56bbd816f> to <7e3ecdcaf9c929d0363e9669ea983080>
[2026-09-09 06:52:57] [Debug] The link to <c2a469aa5151f67153e54616ef162b0e> was closed
This did not happen to me in the past. Am I the only one seeing this?
Reproduced with 1.4.0 and 1.4.1 during several days.
Is this across different propagation nodes, or just one? Have you tried changing it?
Change the prop node you are using. That node has disabled propagation. That's why the link closes immediately.
I see - you are correct of course.
What I had been doing in nomadnet was selecting "Use as default propagation node" in the node info area of nodes I trusted. But this is not a good idea in general it seems: most servers that announce a dedicated propagation node on their nomadnet page provide it under a different separate address. Random propagation node addresses might just refuse my requests.
So - thank you for your help. Hopefully I will only find real errors in the future (or better: none at all).
