Running Nomadnet as service and UI in parallel
Started by C.S.Burner a204b9cc06a94054... ·
C.S.Burner 39a25f495615fa16...
Is it safe to run Nomadnet as service and access the same instance by UI from time to time? Use case: Provide the Nomadpage by runnins nomadnet as a service in the background. Using the UI from time to time to check messages or statistic.
Mmm how would you go about running it as a service and then start/stop/restart the UI? It's something i considered myself but never figured out how to do :)
I do this all the time and it is fine. Pages get served fine when UI is not running and just use UI to edit pages etc.
