this is arguably both showcase and help also but mostly just me raging at stupid stuff lol. so into offtopic it goes.
hi! my name is oatmilk! some of yall have probably seen me around here, not particularly contributing much to conversations other than adding info about the news (like MS being gigafucked), trying to help a friend with setting up the one 1watt board (which we still need to trial for our use case, will get back on that at some point ;-;), and helping Mark fix a bug that one time by providing error logs for a RRC corruption bug (tho that was in RRC and not here so people may not have seen that actually..)
some background that is kinda important. i use windows for my desktop. (i specificity use a modified windows setup that replaces windows explorer (and thus the taskbar, window switcher, ect) with a semicustom implementation (not my own, is publicly available, can talk more about it at some point.)) i shoullldddd probably swap over to linux at some point, but have a couple games that i like that don't have wine/proton support due to the devs being jerks, also need to get around to deciding what all to keep, backing that up and then moving that around, inertia is a bitch. anyways, because of running windows, it looks like i am part of a small subset of nomadnet/windows users, and would like to report that it's great, other than the fact that windows terminal doesn't support kitty's image display protocol (and likely won't because those devs are jerks) and there's some weirdness with some shortcuts getting eaten by the windows terminal.
because of this (and also seeing some people using a personal server for RRC bouncer purposes) i decided to put rns (and nomadnet) on my personal VM that my roommate runs off a home server. however, there's a couple issues with this.
issue one:
cockpit (the remote access web console i run on my vm) doesn't support nerdfonts, becuase it doesn't support changing fonts at all. >:( looking for suggestions on replacement software for this if possible :/
issue two
my vps setup doesn't support a display setup lol. this can't really be fixed, and is just going to be something that i cope with, as it's supposed to be a headless server anyways. :P
question for all yall
if i wanted to set up said headless server as a transport node (or maybe even a propagation node) but didn't want to have others using it (i don't want to be responsible for dropping users packets and such if it eats shit (like it does every time it restarts) and would feel bad) , what setups would make sense for this? should i just say fuck it and let the `ret use it for normal network traffic since RNS as a whole tries to fail gracefully? does it make sense to have your propagation node on the same power and network as your end user device? (i'm thinking not but that could just be me).
thanks!!
