First rnode - Is there anything I need to know that might be helpful?
Started by Camphoria ·
So I started ordering parts to build my first RNode. I'm intending ultimately to create a 433/867 multi interface node initially and possibly add HaLow down the line, with solar/LFP battery power, 4G LTE for the internet side and the package mounted on the side of the house about 15m off the ground. I think it will be the first RNode in my city. There are some in other cities, but not in mine.
I have on order (so far):
  • Lilygo LoRa32 T-Beam v1.2 433MHz
  • diymore LoRa SX1262/ESP32 v4 867MHz (not sure if this is Heltec or a chinese rip off of the Heltec module, but several reviews say it works with meshcore and it appears to use the Heltec V4 fw)
  • KickPI K2B 4GB Ram / 32GB eMMC (will be running Debian 13 / Armbian)
  • 2x USB PD/QC3.0 12V Car surface mount sockets to provide 3A to the KickPi and potentially the 4G LTE Router.
I already have a Victron 75/10 MPPT, a 30Ah LFP and a 120W solar panel.
What I don't have so far are the antennas. I think I need a 70cm fiberglass for the 433MHz and a decent Omni for the 867MHz. I also haven't decided on which 4G LTE module to use because there aren't many standalone aside from the USB or MiFi systems. I ideally want something powered from 12V DC or USB with external antennas, like the Huawei B525 router, but smaller and less power hungry. I also want to limit the data sent through the 4G to a max of a couple GB per day as I have limited funds for the internet connection and there won't be any network access outside of Reticulum. The 4G is mainly there to add worldwide connectivity since I probably won't have any other local nodes until I can find likeminded people who are up for buying some kit and shoving it on the side of there houses.
I am using the Nodestar guide for reference so far and will be using the UK settings for the LoRa side.
My plan is to connect to the wifi on the KickPI for local connection (node maintenance, OS maintenance, general need to hack or upgrade stuff, maybe connect to Reticulum if there is away to connect via localhost).
Does that sound workable? I'm new to Reticulum, but I've been using Linux for 30+ years, have an IT Degree in Computer Networks and experience in deploying i2p, tor relays/bridges, XMPP servers, IRC servers, game servers and much more. :D
