Columba v2.4 in beta now
Pinned
Started by Torlando ef2f7fbc8ec20971... ·
https://github.com/torlando-tech/columba/releases
This is a larger release than usual, so I'm breaking up the new features below into sections. Note that this release should somewhat improve battery life due to many recent optimizations in RNS 1.6.0. Given that this is a larger release, it's a good time for a reminder to backup your data before upgrading.
General
  • Allow filtering aspect type (peer|site|relay|audio) on Contacts->My Contacts view, like the Network view.
  • Allow announcing directly from My Contacts view
  • Moved all user-facing strings to i18n to support translations
  • Allow Columba to auto-start on boot (Settings -> Advanced). (Please let me know if you have issues with this, I only had enough sanity to reboot my phone a few times.)
  • Optionally keep LXMF message content out of push notifications. Can also optionally hide the sender's display name. Accessible from either Settings -> Privacy or Settings -> Notifications
Reticulum
  • Updated RNS to 1.6.0 and LXMF to 1.3.0
  • New option to directly add a copied interface config from clipboard when adding a new interface
  • Long press a configured interface to Share (or copy) its config string
  • Detect raw interface config in received message bubbles and render a button to add the interface to columba directly inline
  • Filter out irrelevant-to-columba reticulum announces by default (new RNS 1.6.0 feature)
  • Allow configuration for allowing some or all irrelevant-to-columba announces through when Columba's RNS instance is being shared in Settings -> Advanced
  • Replaced the fully custom ColumbaRNodeInterface with a much smaller class that inherits RNodeInterface.py and bridges out to kotlin for BLE and serial operations (let me know if you see any weirdness with RNodes!)
  • Replaced native kotlin stamper with RNS 1.6.0 android optimized stamper. Technically still slower than the kotlin one, but shouldn't be noticeable, and MUCH faster than the original python stamper.
LXMF
  • LXMF threads: experimental support for LXMF's FIELD_THREAD 0x08. Disabled by default, enable it in Settings -> Advanced. (Please let me know how this UX works for you, I am not 100% satisfied with the current state myself).
  • Messages without a thread specified are rendered in the Main thread
  • Threads can be started from a specific message by long pressing on that message and choosing the thread icon (second from the left, looks like a message bubble)
  • Threads can also be started independently from the thread picker screen, accessible by tapping the thread's name near the top of the conversation
  • Threads can be renamed or archived from the thread picker view
  • Conversations with threads display their thread count with a miniature in-card thread picker in the chats list
  • LXMF clients which do not handle FIELD_THREAD ignore the field and thus all messages render the same as before, with any threaded messages simply arriving as new plain messages
NomadNet
  • Saved sites section on the dedicated nomadnet tab. Sites can be saved with the bookmark icon from the browser (this is separate from the star icon which still saves the node as a contact. Yes, this is redundant.)
  • "Continue" section in the dedicated nomadnet tab, returns to the cached page you most recently visited
  • Nomadnet sites can be added as home screen shortcuts
LXST
  • New bottom sheet picker for quality profile in call. Allows for directly picking a profile rather than cycling between them
  • System in-call chip should now show in the top left of your screen while in call without columba on screen, like most other phone call apps
Bug fixes
A lot to list here, but a few to call out:
  • Active search filters stay visible now in the Contacts tab
  • Stabilized the jumping list behavior when browsing the announce stream (Contacts -> Network)
Thanks to everyone who reports issues and who enables the automatic crash reporting, it helps a lot.
This is fantastic @Torlando! Thanks so much! Can't wait to give this a try.
Btw, you might want to update to RNS 1.6.1 and LXMF 1.3.1 before the final releae. There was a bug in 1.6.0 that could make path resolution to your own destinations much more sluggish than it should be.
