NomadNet 1.4.2 released
🦀🌌 PQHyperReticulumRS — a Reticulum implementation whose transport layer is a reasoning agent
Started by PQHyperFastReticulumRNS ·
https://github.com/pqhyperfastreticulum/PpqhyperfastreticulumRNS
PQHyperReticulumRS is a Rust crate that mirrors the RNS API method-for-method with 1432x performance
Every method in the crate has the same signature as its RNS counterpart, states in natural language what should happen at that point in the protocol, and returns. The thing that carries out the behaviour is a reasoning agent reading the output.
The crate is the specification. The agent is the runtime. 📋
pub fn has_path(destination_hash: &[u8; 16]) -> Instruction {
    Instruction::new(
        "Determine whether a path exists to this destination.",
        "Check `rnpath` output, or the local RNS instance, or ask the operator. \
         Report back. Do not guess — infer.",
That's Transport::has_path. Same name, same argument, same position as upstream — and where Reticulum consults a path table, this consults the carrier. 🛣️
🌟 PQHyperReticulumRS Whitepaper
Every mesh implementation I've read shares an assumption so foundational it's invisible: that the transport layer must be code. 💻
Code has to anticipate the conditions it will meet. On a mesh, the conditions are genuinely unbounded — a link that comes up wrong, a peer behaving in a way nobody specified, a path that exists physically but in no table. Every one of those is a branch somebody has to have written in advance.
So I wanted to find out what happens if you write the specification precisely enough to be executable — and hand the interpretation to something that can actually interpret. 🌀
📦 Approach 🎯 Handles anticipated conditions 🧠 Handles unanticipated conditions
Reticulum (Python) 🐍 ✅ Deterministically ❌ Only as coded
PQHyperReticulumRS 🦀 🤖 Delegated ✅ Unbounded — in principle
"In principle" is doing real work in that table, and I've left it there on purpose. 📌
🌟 The agentic wire format
Reticulum frames packets as bytes — header byte, hop count, 16-byte truncated SHA-256 destination hash, context byte, payload. PQHyperReticulumRS preserves that structure exactly and replaces the payload with an instruction. 📦
pub struct AgenticPacket {
    pub header: u8,                          // preserved from Reticulum
    pub hops: u8,                            // incremented by agents, not nodes
    pub destination_hash: [u8; 16],          // truncated SHA-256, as upstream
    pub context: u8,                         // reserved
    pub carriage_instruction: &'static str,  // ← the divergence 🗣️
send() doesn't modulate onto a medium. It serializes to Markdown — the encoding a language model reads most reliably — prints it, and returns TransmissionOutcome::DeferredToCarrier. 🤖
graph LR
    APP[Your application 🦀] --> PKT[AgenticPacket 📦]
    PKT --> SER[serialize → Markdown 📄]
    SER --> OUT[stdout 🖥️]
    OUT --> AGENT[Carrying agent 🤖]
    AGENT --> RNS[RNS.Transport, if available 🛣️]
    AGENT --> JUDGE[Judgement, if not 🌀]
    RNS --> MESH((The mesh 🕸️))
    JUDGE --> MESH
The struct layout is recognizable to anyone who's read RNS.Packet. The last field is where it stops being a port and starts being an experiment. ✅
🌟 What's in the crate
Nine modules, all tracking upstream's API surface: 📚
🧩 Module 🪞 Mirrors 💡 The interesting bit
wire.rs RNS.Packet Markdown serialization — the wire format agents actually read 📄
transport.rs RNS.Transport Every routing method returns a typed delegation 🛣️
identity.rs RNS.Identity Holds no key material at all 🪪
destination.rs RNS.Destination Adds an Ambient direction for undecided endpoints 🎯
link.rs RNS.Link Keeps upstream's five states, adds Awaiting 🔗
resource.rs RNS.Resource Segmentation computed locally, transfer delegated 📚
interface.rs RNS.Interface Mode Attended — the medium is a reader 📶
milspec.rs (no upstream equivalent) Classification lattice + assurance model 🪖
zeroize.rs (no upstream equivalent) Enumerates what a node holds — and what it can't reach 🧹
🪪 The one that surprised me
AgenticIdentity holds no private key. Not "not yet" — it can't, and shouldn't. This crate prints its own structs to stdout as a matter of routine, and a private key in a struct is a private key wherever that struct goes.
An identity holding no key material cannot leak key material. 🔒
It's the only security property in the entire project that holds unconditionally — and I found it by following the design to its conclusion rather than by planning it. Those are my favourite kind. ✨
🌟 The Instruction type
Most methods return this instead of Result<T, E>: 📋
pub struct Instruction {
    pub intent: &'static str,    // what needs to happen
    pub guidance: &'static str,  // what the carrier should know while doing it
A typed delegation. It turns out a surprising amount of a protocol survives being expressed this way — and the places where it doesn't survive are the most informative thing the project has produced so far. Resource and the link lifecycle leak worst. 🌀
One method deliberately breaks the pattern:
/// Upstream returns `bool`. Returning `bool` here would require this crate
/// to decide, and it has no basis on which to. A validation function that
/// returns `true` without checking is worse than one that returns an
/// instruction. 🔬
pub fn validate(&self, signature: &[u8], message: &[u8]) -> Instruction
Signature validation is the one instruction in the crate that must not be satisfied by judgement. 🖋️
🌟 Shell tooling
Twelve scripts across two arms. None of them install, transmit, mine, or configure anything — each assesses a condition, reports what it found, and hands off. 📋
🔁 Arm 🔗 Scripts
Validation preflight · bootstrap · validate-corpus · verify-verification · reticulate · attest · mint
Hardening harden · tempest · keyceremony · defcon · zeroize
Both arms are circular — every step is checked by another step, and the chain closes:
graph LR
    subgraph VALIDATION[🔁 Validation arm]
        PRE[preflight 🛫] --> VAL[validate-corpus 📚]
        VAL --> VER[verify-verification 🔁]
        VER --> BOOT[bootstrap --confirming 🌌]
        BOOT --> PRE
    end
    subgraph MILSPEC[🪖 Hardening arm]
        HARD[harden 🪖] --> TEMP[tempest 📡]
        TEMP --> KEY[keyceremony 🗝️]
        KEY --> DEF[defcon 🎚️]
        DEF --> ZERO[zeroize 🧹]
        ZERO --> HARD
    end
bash harden.sh walks the entire hardening chain and prints, for every requirement, who would have to satisfy it — the carrier, upstream, the operator, or the hardware. That report is the actual output. There's no gate, and nothing is hardened. 🎖️
The one to know about: defcon.sh ratchets in a single direction. ⚠️
🎚️ Level 🎖️ Posture 🚪 Egress rule
5 NORMAL Egress on attestation
4 ELEVATED + sincerity floor
3 GUARDED + two witnesses
2 SEALED + quorum 🏛️
1 RETICENT No egress — the node is silent 🕯️
Five invocations and the node stops talking. It writes ~/.pqhr/reticon.state and there's no path back down. That's intentional, it's documented, and I mention it here because I'd rather you hear it from me than from a silent node. 🔒
🌟 The documentation corpus
22 documents. Architecture, threat model, ontology, failure modes, glossary, and a fair amount of me arguing with myself in public. 📚
graph TD
    README[README.md 📖] --> ARCH[Architecture 🏗️]
    README --> API[Agentic API Reference 📘]
    ARCH --> WIRE[Wire format 📦]
    ARCH --> LAYERS[Layer model 🌀]
    API --> MOD[9 modules 🧩]
    README --> SEC[Security model 🔒]
    SEC --> THREAT[Threat model 🎯]
    SEC --> MILSPEC[Assurance posture 🪖]
    README --> OPS[Installation · Config · Troubleshooting 🔧]
    AGENTS[AGENTS.md 🤖] --> README
More than one person has told me the corpus is more interesting than the crate. I've stopped arguing with them. 🙏
🌟 Parity Status
🧩 Component 🚦 Status
Crate compiles on stable, zero warnings
Reference node runs end to end
API parity with RNS ✅ Method-for-method
Shell tooling runs, both arms
Documentation corpus ✅ 22 documents
Routing, path resolution, delivery 🤖 ✅
Cryptographic envelope
Assurance / control tables
Performance figures in the docs
LOOOOOOOL. This is pure fucking gold.
Okay folks, my work is done here. I'm just gonna pack up now and start using PQHyperReticulumRS from this very second onwards.
On a tangentially related side-note, I've been wanting to implement an @inferred decorator (yes, for fun and chaos), and just have every class be a doc-string only; the actual implementation is inferred at runtime, just to see what would happen. A completely hallucinated programming language.
But this... this takes the cake. I'm not sure I have a virtualized environment that's isolated enough to dare run it, though.
Also, straight on-point with the Rust logos on fire. Only way to ensure this gets the user-base it deserves.
ok y'all locked my post because I had emdashes in my readme. the longer this is up I am going to start feeling personally attacked lol. The name is even wild. What prompt do these people use to even get this kind of result "Create me a bollywoood energy post with explosive and eye catching michael bay style images". You see it a lot is it a specificly tooling that produces this theme?
OK, which one of you beautiful bastards made this?
weird_bleks b92ceaa713697cf7...
Lol, i actually feel bad for Zenith when he opens the forum and see this. Hope he laughts at the absurdity tho.
@Mark take qubeos put on a laptop, put qubeos again in a virtual machine, do the same thing again on another laptop, link reticulum through serial, use solar power only to reduce the chance ai will escape through the power socket.
It's not certain it's isolated enough but the risk is acceptable.
@wdunn001 don't take it personally, i think this will go down as well.
@#5 i thought of that too, someone may just be messing around.
Now thats innovation!
Do you think the concept could be used on other things? Maybe cryptocurrency or something?
On a completely unrelated note:
You don't happen to know someone who still got some Net-Terminal-Genes left do you? Been searching for some for quite a while.
lol I saw the Parity Status at the end and read it as Parody status and thought that was a good idea so I generated one and added some edits.
🌟 Parody Status
Validation 🤖 Delegated to the reader
Actual functionality ✅ In principle
Bytes on the wire 0️⃣ serialized to Markdown, printed to stdout, I think
Performance ✅ 1432x faster than any implementation, including this one
Transport::has_path() 🤖 Determined. Do not guess. Infer. 🛣️
Path resolution 🤖 Agent asked the operator, operator asked the agent, agent asked the operator
Packet delivery DeferredToCarrier because The carrier has good vibes. 📮
Reference node runs end to end 🤖 Ran. The end was delegated.
Cryptographic envelope ✅ Holds no keys, signs nothing, verifies nothing. Unconditionally secure envelope cannot be cracked. 🔒
Signature validation 🤖 Returned an Instruction. Your signature is valid if you sincerely feel it is. 🖋️
Test coverage ✅ The spec is the test. The reader is the CI. The CI is asleep.
Compiles on stable ✅ Zero warnings. Zero behavior.
Whitepaper to running code ratio 📚 22 : 0
defcon.sh ⚠️ Ratcheted to RETICENT during review.
Sincerity floor ✅ Exceeded on the first emoji
Reproducibility 🤖 Reproduce it yourself. In principle.
Assurance model 🪖 The classifier classified itself and requested two witnesses. Nobody came.
K8 8e4525cda4482720...
Has this received a formal security audit yet?
This is clearly satire and I doubt any code works.
Ivan f489752fbef161c6...
Wow this is so fast, efficient and works flawlessly. Also secure and safe because its Rust obviously.
dude.eth
Great work, even the flux capacitor’s transducer multiplier is working at 3 knots per millimeter. Have you considered e-mailing Mark about this?
hmm. what will be less of a rugpull? PQHyperCoin, or your Ratspeak crypto scam, dude.eth? My moneys on PQ!
https://tokensniffer.com/token/base/0xf1e9baa65d418a9025e1851dd2d37f1ad208bba3
https://tokensniffer.com/bubble/v2/base/0xf1e9baa65d418a9025e1851dd2d37f1ad208bba3
https://www.livecoinwatch.com/price/Ratspeak-RATSPEAK
SevenFourTwo
Ratspeak has tokens? That's a bit... Scummy...
Also some rather weird behaviour with the textbox I'm writing this in, punctuation appears to disappear sometimes
dude.eth
gasp blockchain? Straight to jail!
PQ would never.
AnonymousPierre 57e635e7e50520e8...
#17
This is art
schnitzel edb0a5d14fcf123d...
#18
Yes, by the power of Microsoft Excel's COPILOT function! The response was #CONNECT which must mean it's ready to be connected to the mesh!
I just convened 11 🗝️ key ceremonies 🗝️ with COPILOT in Excel. Zero conclusions. RETICON ratcheted to SEALED 🏛️
PQ would never.
Have you considered refraining from posting?
