Reticulum in JavaScript
Showcase
Started by bergie f9477df559d52317... ·
I've mentioned this on the forum a few times, but now that it is actually partially functional, I think it deserves its own thread:
reticulum-js is a new JavaScript implementation of the Reticulum network stack:
https://reticulum.js.org/
Available on rngit:
rns://adafb3153efd4d96d532568a5208b3b5/reticulum/reticulum-js
and also mirrored to GitHub:
https://github.com/bergie/reticulum-js
What works now:
  • TCP and WebSocket interfaces
  • LXMF messaging both direct and over a link
  • Requests and responses (tested with both NomadNet sites and rngit work documents)
I'm building this mostly because I need Reticulum capability for two systems I'm working on:
  • Integration with Signal K "smart boat" platform (Node.js)
  • Online collaboration for the new NoFlo visual programming editor (browser and Node.js)
So features needed for those have priority. However, down the line it would be great to have the full RNS spec supported. This means a browser app could theoretically be a transport node!
Reticulum-js has been written with assistance of various LLMs. Not ideal, I know. But right now I need to balance sailing and getting this working quickly.
If anybody is interested in this, I'd love some feedback. Especially:
  • General API ergonomics. I've tried to keep it quite "modern JavaScript" and lean heavily on Promises etc
  • Ideas for interfaces that would work for browser applications (WebBluetooth? HTTP POST? ...)
There are some usage examples I. The examples/ folder.
Looks interesting!
Here's a Reticulum connector for the Yjs CRDT system. Still needs work (for example, switching to Link Channels, and transferring larger CRDT packets as Resources):
https://github.com/bergie/y-reticulum
I was able to use that with CodeMirror and do browser-to-browser collaborative editing over Reticulum, discovering room peers through announces.
This will make more sense once we have a WebRTC interface, though I'm curious to see whether collaborative editing is practical over LoRa.
Lol, the logo had me laughing so hard. It's not RNS anymore, now it's just "JS". It's brilliant.
Sorry, no constructive comments here, just had to share the laugh. Need to take a proper look at this first when I have some time :)
Thanks! The "Reticulum" is in the constellation ;-)
Perfect, any comments would be appreciated! I'm sure in these first versions there are a dozen things I'm doing a stupid way.
I just released 0.4.0 where the project is split into multiple packages:
  • @reticulum/core is the actual Reticulum implementation without any external dependencies
  • @reticulum/node adds Node.js specifics like shared instances, filesystem persistence, TCP interfaces etc
  • @reticulum/webrtc-node adds WebRTC interface for Node.js (as we need a 3rd party library here unlike in browser)
  • @reticulum/websocket-server-node adds WebSocket server interface
In addition to rngit releases and NPM, the project is now also available in JSR package repository https://jsr.io/@reticulum/core
0.6 series added some big features:
  • Ability to run as LXMF propagation node
  • Ability to run as RFed client or node
  • Interface gravity and link path re-balancing
  • IFAC support
  • SSL support for WebSocket client and server interfaces
Backwards compatibility break in that @reticulum/core no longer exports LXMF or RFed interfaces on the main module. You instead need to do a deep import. This is to reduce bundle size for typical browser applications.
Available on rngit, NPM, and JSR.
What's needed before 1.0? At least transport node capability, and a ton of real-world testing.
edited #9
0.9 is out now (as always, available on rngit, NPM, and JSR):
  • Lots of reliability and bug fixes now that we've been able to use this in production for a couple of months
  • Added BackboneInterface to server-side environments
  • Added rngit transport for isomorphic-git. This means JS git clients can pull and push rngit repos
  • LXMF and RFed were split into their own packages (actually in 0.8 already) to keep core smaller
Docs in https://reticulum.js.org
Just wanted to say - thank you. Websocket implementation should enable more servers to pop up as they can now sit behind a new reverse proxy, and they would not need to deal with port forwarding etc. Maybe we can lift this back into core implementation - but im also happy to replace my servers to js implementation too.
