Retipedia v3
Showcase
Started by Zenith ·
Retipedia v3 has been released
https://github.com/RFnexus/Retipedia
https://codeberg.org/rfnxdev/Retipedia
rngit: rns://4cf8a0651c4d73cacd0f93ac1d95e80a/public/Retipedia
There is now support for:
  • iFixIt, with initial image rendering support
  • _maxi Wikipedia archives with initial inline image support
  • StackExchange
  • MedlinePlus
Readers can now select a text layout style, with narrow, center, and wide options. Gutenberg now has full bookshelf support and better parsing, and loads in parts by default with chapter or section titles.
If you are running NomadNet >1.4.0, enable images in the settings with:
images = True
in settings.py. Image files are cached under the Retipedia root directory under images/
Btw, did you know you can change the accent_color too? Get in the Autumn mood with orange
Hell yeah, this is awesome! Great work Zenith!
Been wanting to set up a retipedia instance for a while, and now I really gotta bump that one up the priority list :)
By the way, how are you doing the image conversion to webp? (Sorry, haven't looked at the code yet)
Did you use the live-converter from rngit? I wanted to generalize that one so it was easy for other programs to import and use exactly for stuff like this, but didn't get to it yet, so I'm not sure if it would actually work well in external programs.
Ah, it looks like it's just grabbing it in whatever format is in the zim. Time for me to get live-conversion added to nomadnet itself, then ;)
