RTNode v1.0.36 - Multiple WAN TCP interfaces
Started by jrl290 ·
You can download and install here:
https://jrl290.github.io/RTNode-HeltecV4/
You can configure up to 4 server TCP interfaces to connect to. Should increase reliability. Keeping in the spirit of the ESP32, RTNode does not pass announces or packets across these "WAN" interfaces. Only outbound and whitelisted destinations are passed through to the LoRa and Local TCP Devices
Also some clean up of the display
daylight-hub
Does this work to pass messages using autointerface from MeshchatX to the RTNode LoRa radio when it is configured in client mode to the same home router as the computer running MeshchatX?
It does not support AutoInterface. You can however simply add the TCP address to your MeshchatX interfaces
daylight-hub
Okay, so I assume run a tcp server onRTNode and then add a MeschatX tcp client?
Would you consider making another version of RTNode that is a basic RNode with the really nice user interface of the RTNode that allows setting up WiFi, turning on TNC mode, etc.?
That is correct
Sadly I have very much to maintain as it is
