I think I should have made this topic a while ago, but it's better late than never 😄
You probably know of the Micropython reticulum port I made a while a go. I try to keep it up to date with the new RNS versions, while omitting some to match the constraints of esp32s3.
As a sister project, I started T-deck V1 and Plus firmware which is based on Micropython port, but adds UI, specific for the T-deck hardware. This firmware has the following features:
- TCP and LoRa client interfaces (UDP also supported, but not exposed)
- LXMF client:
a. image support - opens webp and jpeg
b. voice support - send and receive codec2 (medium quality only) - Nomadnet client
- rnsh client
a. 80 cols terminal
b. font is a bit small, but on 640x480 screen, that's the best I could do. - RRC client
Anyway, the reason for this post is actually T-deck Pro which I got today and was able to fairly easy get working with the existing firmware. There are still some e=paper specific tweaks I need to make, but it's generally working fine 😁 I'll upload the firmware probably tomorrow to the repo above and will make a showcase Youtube video.
