Live interface reload and control
Pinned
The latest source version of RNS on Aleph (1.5.5) has added --attach, --detach and --reload options to rnstatus.
This means you can now stop, start and reload interfaces live while an RNS instance is running.
I'll have this out relatively soon, but if you try it out in the meantime, let me know if anything is wonky.
The API functions are also exposed (Reticulum.reload_interface(name), et cetera), so applications that provide interface controls can use this for much easier hot-reloads, instead of having to restart the entire instance. It uses the latest config values from the configuration file on each attach/reload.
Enjoy!
deavmi 869bbca773f29371...
I was just thinking about this being one of the things I wanted to add to my impl. About 5 minutes ago. Then I see this. (coming from i2pd, live reload is nice, although idk if i2pd's works)
One question, for us Docker users, would it make sense if I could contribute some code whereby this same functionality could be triggered by a UNIX/POSIX signal? As I could (i think) probably put something together to send a signal into the container. I mean, I guess I could also just docker exec reticulum_container rnstatus --reload, yeah that would work. Nevermind :)
That sounds quite useful. Thx a lot!
I would guess this also works with rnstatus remote managent, but I could be wrong
Fantastic! Will get this added to Columba as soon as I can. Thanks Mark!
Necom ee66ebab74823858...
Strange how the web version says the latest reply on this post was 1h ago, but then when I actually check the latest reply is from September 28th
