microReticulum transport <-> rnode interface (on rnsd)
Started by deavmi d222df7f01f82f75... ·
deavmi 869bbca773f29371...
Did something change with the way the RNodeInterface and microReticulum worked recently. I used to be able to use my handheld RNode and hop through a transport node on my roof that is running microRetciulum. That roof node would then hit an RNode (connected to rns via an RNodeInterface) and to the rest of the network.
Now it seems broken. I also noticed that the default mode for RNodeInterface went from gateway to accesspoint. I corrected it back to gateway. I run all the nodes like that although I suspect gateway for the roof node makes more sense.
Either way help would be appreciated. I did set the airtime limit to 0.1 of the roof node so I can't tell if that drastically impacted it but it feels like it straight up doesn't work.
If I open the ChadConsole (very based, thats what I call the microReticulum console) then I do see traffic. It has enogh flash storage too.
