when being an idiot (yes i know lol) and having a i2p connection in your config file, while not having i2p or i2pd installed on the system (or maybe not running??), and then going to disable it through the nomadnet UI for interface management (and then going to restart your RNS system) RNS(d) (and nomadnet) will not open due to content not actually added by the user.
i'll make a ledgeable bug report prollllyyy tmr afternoon, it's 4:30am and i need to get some sleep
[[Catz Node I2P]]
type = I2PInterface
peers = f77ptezksg4qr4rdike5t2kj3hh2oa7l7qmohqwow6uc6evzjjtq.b32.i2p
is what i put into the nomadnet through
when i added it, i had a I2P implementation installed(and running, but was unable to connect). i only removed I2P after restarting the first time to see if i could get a connection, and deemed i couldn't, and thus gave up.
after disabling it through [C-o] in nomadnet to try and come back to it later with a more rested brain.
the lines that caused
to happen were added
unsure if this is intended behavior that lacks a sanity check, or an actual significant bug i found by being a dumbass
